My driver side window stopped working the other day. Took the door
panel off today and when I try and put the window up it just clicks but
doesnt move and its stuck all the way down right now.
Is what I have circled in the picture what I have to replace?
maybe test the motor to see if thats the problem
if you need that relay thing let me know i think i have one or two of them
Thanks but all i did was give it a hit with my hand and it works better then before now
haha
Brandon. Pwnter of said window regs. lol
That box is most likely what is couseing it not to work. You can use one from a USDM car.
Glenn’s super nerdo/bored fix:
this happened on one of my old cars and i’m sure nissan’s control box does the same thing
if you take that box off you can dissasemble the cover there will be an electrical board underneath, if you flip it over to the flat side you’ll see a bunch of solder connections, typically one of those connections will have a crack in it (when you hit the door panel it temporary reconnects them) just lay some solder down and make a smooth connection and you’ll be set
or you could go to the junkyard and pick one up for 5 bucks or hide it under your shit/in your toolbox
lmao, We’re all accused of doing it.
:lol:
