power window problem - please help!
Alright so its a 95 240sx LE and the driver side power window doesnt seem to work. I changed the regulator out because thats what i thought the problem was and nothing. When i hit the switch to open the window there is just a clicking noise, there is a white box just below the door handle that says AMP AUTO P/WDW and the clicking is coming from inside there. Is it a relay or something, is that the problem?
I dont know what the problem is, any help would be appreciated,
thanks in advance
Mark
ya its the relay, jsut replace that and you should be fine, any one will work pretty much just go to pick your part, take your old one and compare, i found one at kar bashers when i needed one.
thanks a lot
Just replace the whole thing, switch seems to be working properly it’s just the clicking noise that bother you - gonna love fixing it.
power window switch
