little up date bought seat brackets, passenger 5 point harness and weld racing lugs.
Bolt on the parts and take pictures! Cool thread
new seat in drivers side, passenger side behind seat still needs to be welded in cause my arc welder crapped out on me before i got the change to weld in the need piece >.< so im gonna finally just get a wire feed TIG welder.
the rear welds are on need to order front tires unless someone has a pair of 155/60r15 laying around
It’s a shame your harness is attached that way.
well. its actually worse than a shame. Its dangerous. Don’t get hurt bud.
The reason for this is to prevent spinal compression in the event of an accident. Improperly mounted belts can cripple or kill. Stay safe
Yeah I know everyone was telling me the same. I might be getting a harness bar till I can get a cage put in
If you can weld just make one or buy one cheap and tack it in.
found a bolt in cage that isnt that bad looking. i would be welding to the floor instead on bolting to be safer. anyone deal with bolt in cages?
http://www.vividracing.com/catalog/-p-153537.html?utm_source=adwordsfroogle&utm_campaign=adwordsfroogle&utm_content=97759&ph=1&gclid=CN6EmYTuubkCFZCe4AodyHwA3w
picked up a sn95 5.0 throttle body for less then 30 bucks, gotta redrill two mounting hole and hog out the upper intake manifold but besides that its a direct swap
[ATTACH=CONFIG]24744[/ATTACH]
will post a little more next week when the parts i need come in
pick a weapon r coolant tank since my monster can isnt really practical lol
[ATTACH=CONFIG]25086[/ATTACH]
got a new lower shift boot from American muscle
[ATTACH=CONFIG]25087[/ATTACH]
and here is a updated pic of the engine bay. intake pipe and hoses and misc parts. finished the egr/smog delete
[ATTACH=CONFIG]25088[/ATTACH]
also put a light in the interior cause as of late i’ve had to drive it. gf focus alternator went last week then her car got hit on the side of the road where it was sitting. so shes driving my malibu aka winter beater
[ATTACH=CONFIG]25089[/ATTACH]
so my plans for winter is
- gather suspension parts and rollcage
- buy 94-98 stang for 5lug disc brake swap and maybe 5.0/4.6l engine swap
I got a 5 lug swap available. If your interested send me a PM.
Sweet project!
Txt me when u wanna do a cage
I like your style.
im actually more interested in a rolling sn95 so i can swap the spindles and axle to get a stronger and reliable swap. did some research and found Latemodelrestoration.com sells all the hardware to convert to sn95 brakes. not knocking the swap kits but buying a thousand buck stang at least i can swap everything turn around, part the donor stang out and scrap the shell. that way im getting my money back, like i never spent a dime on it.
- Updated - - -
thanks trying to do something different since everyone does a 5.0
