ok, I’ve got pop up with lights on, but switch alone, doesn’t do anything I get a click of a relay but no movement. they go up when I turn on the lights and go down when I turn them off…
2nd problem, I have hazzards, but nothing happens with the turn indicator. nuffin, no click (aside from the mechanical click of the switch) nuffun… I dunno
I’m guessing fuses and relays. but it’s dark out now and I don’t wanna mess with it anymore
thanks
Could be the switch itself. Don’t rule that out… plus it’s easier to check than the relays. All the problems could be attributed to bad contacts on the end of the light stalk. Try a new one… they aren’t expensive.
