how do i find out if i have abs or were would it say i have a 95 nissan 240sx and im sure i do not have abs but before i order a 500 drive shaft i want to make 100% sure
look on ur master brake cylinder…if theres only 2 hard lines goin to it, its got abs. If theres 3 hardlines goin to it, non abs
y is there less lines for abs then non
Because the front each have their own line where the rear are on the same line. ABS just has 2 because the ABS control unit has the other lines…
