quick compression question
ok if i was to build a lsvtek and if the compression on all four pistons are 270 is that good or bad…
ls block everything b16…
i do not know much about motors so i am askin for nys help!
That would be fantastic, actually those numbers sound a bit higher than I would expect.
270 across is about right, it all depends on compression testers, some are more accurate than others
what really matters is how consistent they are with each other
