do you need door moldings/trim in order to use this pullup bar.
yes or no
link to follow soon (stupid phone)
<3 scott.
yes or no
<3 scott.
inb4link!
no u dont need door moldings, u just need a frame
no
No
k now go back and look at it.
by the way why are the engineers struggling to get this uggggh
no
If it relies on the molding to hold you up, you will most likely rip the molding right off the frame. So, this is a big NEGATIVE. Not needed.
lol this backfired somebody ill wait for him to buy it and prove you all wrong Lol. im not saying its putting a ton of force on the moldings but it won’t work without them.
“the plane will take off”
did u change it or something? it now says “needs border trim” :snky:
its always said that. youtube it and see how it works then comeback and answer
you need a door frame, I have it, with out it you have nothing distributing your weight
No…build a metal frame and weld the pullup bar to the frame…
ok no but look at the ad in one sentence is says “This is a great doorway pull up bar and can be used on any sturdy door frame. You don’t need a large area to use this Chin up bar”. and in the other it says Fits doorway up to 32" wide (sturdy doorway with border trim required). so i deff think they dont know wht they are talking about.
all you need is…
COCK
since it looks like there is a tension setting on the other side. (the side that wouldnt hook to the frame if it rly needed to) i would say no because as long as u can keep pressure against the frame on the other side then both sides will be tensioned to the door frame. I dont think u need molding, but it wouldnt hurt.
I’m going with it goes on the door molding, so as long as it’s not a pocket door or some really weird shit then no
Isn’t this the same concept as that iron gym shit? One of my friends bought that and he didn’t have a single doorway in his house that it would work with without removing a door. rofl.
Oh and my brother bought it and he’s having the same problem. These things seem silly. I guess they are the modern day ab roller.
finally a man who gets it
