So, I just read Sasha’s offset/wheel thread. I’ve got a basic idea now but I’m still a bit iffy.
I’m looking at those buddy club’s for sale on the board here, ( http://www.son240sx.ca/forum/viewtopic.php?t=12061 )
“17x7JJ, 15lb, gun metal
+42mm offset, 4x114.3 Bolt pattern”
If you guys dont mind I’d like some help breaking that down.
“17”, I got that much figured out
“x7jj” I got the 7 also I hope (7" wide?) but what is “JJ” ??
“+42mm offset” now, this is fine I understand what offset is (the distance the mounting bracket is from the centerline of the tire) and after reading Sashas post I believe positive means it’s towards the outside/front of the tire. But, +42mm sounds very high, is this high or if I threw these on to my s13 with no mods or anything would it look fine?
From what I can tell this is just going to not be “flush” like Sasha keeps going on about. I don’t care so much about that, I just want it to not look retarded and not have any problems clearning anything, anywhere. Even after I throw on my megan coils and play with the manual ride height adjustments. ;] ;]
Thanks for the help as always.
-J
