Hey guys, i am almost done my swap and im really stuck on the wiring. I have almost everything wired up for the most part, im just not sure about the ignition start wire because they dont seem to be the colors specified in the “write-ups”. When i turn the key all my lights on the dash go on like they should, but when you turn it all the way the starter just doesnt crank. Im pretty sure i have the lower harness hooked up fine, ive checked it over many times. If anyone that has done rb wiring before can chime in and see if i did anything wrong, please help me out.
DASH PLUG WIRING:
Whats connected already:
KA-RB
-yellow/green stripe = yellow/green stripe
-yellow/red stripe = yellow/red stripe
-brown/yellow stripe = yellow/blue stripe
-black = black
-black/pink on the s13 dash plug is fuel pump i extended it into the engine bay to the black/pink in the brown plug (blue wire in pic)
Wires still available, RB Side:
-Teal (pin43 ignition start signal)
-Blue/black stripe
-Tan
-Orange/black stripe
-Teal/red stripe
KA Dashplug Side:
-Green/black stripe
-Green/white stripe
-Solid Green
-Green/yellow stripe
-Green/blue stripe
-Green/orange stripe
-Teal/black stripe
-Teal/red stripe
-White/blue stripe
-Yellow/white stripe
ENGINE BAY PART:
GREY OVAL PLUG: whats connected (RB-KA)
-Black/red stripe = black/red stripe
-White/black stripe = Red
-Green/yellow stripe = green/yellow stripe (in s13 brown plug)
Whats Not Connected:
http://i.imgur.com/5OMus.jpg
[LEFT]RB Wire:
-Light blue
-Red/green stripe
-Red/yellow stripe
-Teal/white stripe
S13 Grey Plug:[LEFT]-Black/white stripe
-Blue/green stripe
-Green/blue stripe
-Orange/blue stripe
White/purple stripe RB wire goes to the White cable inside the thick loom by the fuse box.
[/LEFT]
[/LEFT]
