i bought a wiring specialties for my rb25 and it fired right up, even tho the engine came with a harness. But i would start by getting a multi meter and checking for power going to your ignitor and coilpack plugs. lol also looking at the video i would say to make sure you have PERFECT grounds, if you see and previous grounds like the stock chassis grounds by the stock headlights there could be a chance that its corroded and not grounding to the metal, i think you also need to install your TB and tps
Don’t know much about RB25’s but first check to see if your getting 12v to the ignitor harness, check grounds for continuity… Also put your engine to TDC and pull the CAS + fuel rail out. spin the cas by hand to see if injectors fire, then put the rail back in and check if coils fire.
---------- Post added at 03:56 PM ---------- Previous post was at 03:52 PM ----------
if all is good, and your getting 12v and so on, check for ecu codes. wire up the consult port and short it to flash codes on the gauge cluster.
^ yes, but when you have the rb in the 240 all wired up correctly and have the ecu plugged in and turn the knob the code will already flash on the gauge cluster no need to wire up any consult
yeah everything but the premium gas haha, it sounds like a belt is slipping too… i dont have the rad, electric fan, powersteering or intercooler hooked up… and also i have to change the oil and spark plugs.
