rear main seal leaking
Alright, rear main seal is leaking on the new setup, but my motor is still blowing smoke, white smoke so thats oil whenever you get into the gas, smoke isnt consistent, i have restrictor in the oil feed line, would the rear main leaking cause it to smoke at all?
white= coolant
blue= oil
black= fuel
i prolly should mention it is a fresh rebuild but its got id say a lil more then 100 miles on it now so rings shoudl be seated its just weird becuz it isnt consistent
i dont see how it could be coolant, i have that brand new cometic 4 ply .060 but smoke has blueish tint to it, is there any other way you can burn coolant? other then head gasket?
bad block? not sure how your passages are for the coolant but they could be mixing with a cylinder.
do a leak down
I have the same problem on my sohc.I get white smoke and it get hot but not too fast.We got the head resuface and it still doin it.Everything in the block is new so it might be the block is warped.Good luck with ur problem.
just let err smoke its a honda, they ALL do it
RIGHT STUFF FTW
First off,did u check to see if u are actually losing coolant?
