rear Z brake conversion on 4 lug s14…
is the 5 lug hub required and would this work with the 4 lug hub as well and just redrilled rotors
it will work, but you will have to use the rotor from a 300zx and redrill it to fit ur 4 lug. if u want the use of a ebrake u will have to use the 300zx ebrake assembly.
i have all that. i just need to know from someone whos actually done it if the hub is required.
i have all that. i just need to know from someone whos actually done it if the hub is required.[/quote]
nope… i’ve got the z32 setup for my s13 but just have yet to install it as i’m waiting on a bushing kit…
and im still using the s13 4 bolt hub…
all your doing is removing the backing plate/dust sheild etc with the Ebrake assembly and swapping it onto the S14 spindle… its really quite simple.
