I bought a low-mileage 2000 Camaro this summer with several nice upgrades that aren’t part of my end-goal, so it’s time to sell these items. The smaller items I can ship, the larger items i would prefer pick-up. Everything is out of the car ready to go. I am located near Buffalo, NY.
Moser 12-bolt - $2,250.00
-4-channel (abs + traction)
-Either True-Trac or Eaton Posi (need to take cover off to check)
-4.11 gear
-Moser HD rear cover
-Lower LCA brackets
-LS1 rear backing plates
-Zero whine
UMI Adjustable Torque Arm PN-2203 - $275.00
-Black
-Tunnel mount
-Driveshaft loop
C6 ZO6 Chrome wheels with tires - $1,100.00
-Chrome
-Zero blemishes, inside or out
-18" front and rear (not 100% on width, likely 9" front, 10-11" rear)
-Mickey Thompson ET-Streets 305/35/18
-Like new
-BF Goodrich 275/35/18
-Like new
CTS-V Front calipers & rotors - $800.00
-6 piston
-pads and rotors like new
-rotors are drilled
-pretty sure the rotors are zinc coated
UMI (I think) Tubular LCA’s, non adjustable - $75
6Litereater seats with tracks:
$500
This is the only blemish if you want to call it that. On the driver seat, you can see the white stitching at the seam. When you sit the seat, you can’t even see it!
COMING SOON:
T56 Swap - I’m thinking $2,500.00
-33,000 original miles
-No issue’s whatsoever
-Comes with bell housing, Centerforce clutch, master, slave, line, Pro 5.0 shifter, and possibly the pedals.
OTHER ITEMS FOR SALE with 33,000 original miles:
-Aluminum driveshaft
-Rear calipers/rotors (2 sets)
-Front and rear sway bar
-Decarbon shocks
-Springs
-LS1 intake
-ABS control module
I’d love that cts brake swap but they won’t fit 15"s lol
