Put new rotors on and they are rubbing on the metal clips, i measured the old rotors to the new ones, and sure enough there 1/ 16th of an inch bigger :(.
im i screwed ? has any one else had this problem, right now im going to sand down or cut the metal brackets and see if thats works.
anyother help is welcome
you could probably get the rotors machined down around the edges instead of sanding/grinding the brakets so you don’t weaking them. you would have to call a shop and find out if that is doable i have never done this or know anyone that has, but i couldn’t see why not. just a suggestion.
