hey jsut wondering which why i should go? should i press out the original bushings and put the new ones in or should i just replace the whole arm? Which way would be more costy? And how do you adjust the rear camber anyways… it doesn’t same to have any markings on the bushings for measurements
I don’t think the bushing gives you that much adjustablility (1 1/2 Deg of camber or so).
If you are going to slam it, get the RUCAs, but you should get toe arms too…(cause you will run out of adjustability) at that point, you might aswell get the whole kit from Bing.
ya, bit heck the bushing also does not hurt for the fact that well you also get new bushings. so itis a 2 and one
