Got attention? good.
are the S13 silvia and the S13 240sx front brake rotors the same size??
thanks,
Fitzy
thanks,
Fitzy
USDM
89-94 240sx 254x20mm 258x9mm
JDM
91-on RS13 (180sx) 280x22mm 258x9mm 2.0L
So yes JDM 180sx Front Brakes are bigger… 26mm x 2mm is the rotor size and the Caliper is QUITE a bit bigger…
Caliper ( in Canada anyway) is from a Maxima and the Rotor is from an Altima
yeah, i have S13 silvia front brakes, but due to the bitching pads they ate the rotors and i’m wondering if i can get away with using stock 240sx front rotors (not stock, just stock size).
I wouldnt try using a 180sx Caliper with a 240sx rotor
26mm is quite a difference you know.
Just get rotors from an Altima which I believe would be a 1995 range? (I’m not 100%) but Im sure someone else can confirm the year
Just get rotors from an Altima which I believe would be a 1995 range? (I’m not 100%) but Im sure someone else can confirm the year[/quote]
yyour right. 95 (and other same model years) altima rotors and 4th gen maxima pads.
1995 Altima is a 4 bolt??
Thanks, you guys rule!!
Bump from the fucking dead.
for the maxima pads, are they 91-94 or 95-99??
91-94 ![]()
