well mine runs good, it’s actually BSZK’s, and i’m just helping out
the problem goes, he was driving and it pretty much stalls out.
we’ve been working on it for a while now and here’s what we got to.
- fuses seem all good
- we know we have no spark
- when i put a bolt meter across the coil leads i get zero voltage
 but when i have the meter across the + terminal and ground (such as
 sanded down part of the bay or the engine block) i get somrthing like
 10.33 volts
Then i figured, “well it’s gotta b the fkin ground” so i tried
a) un hooking the negative, putting a fresh wire in between new ground and
positive… result? no reading on the volt meter whatsoever
b) with the negative still on, added a fresh wire going from the negative
to the ground… result? blown fuses everytime.
http://www.ctech.ca/npclub/npclub/reparation/ecu-diagram.jpg
i looked at the wiring diagram… but… can’t really figure out the problem
by that.
I’m going to try connecting positive and negative together, close the
existing circuit without going to the coil  and try drawing power
straight from the battery…
u think it would work? any suggestions?
