Check out my most updated list here:
http://www.son240sx.org/showthread.php?283486-S13-Parts
I have some S13 parts for sale. It was a daily driver up until a few weeks ago, everything is in good working order. The parts available are:
-SR20DET 5 Spd Bellhousing
-100% COMPLETE 5 Spd Swap SOLD
Includes:
-Transmission
-Short Shifter
-5 Spd Non-ABS Driveshaft
-Clutch/Flywheel/Bolts
-Release Fork/Throwout Bearing/Pilot Bushing
-Clutch and Brake Pedals
-Master and Slave Cylinders
-Hardline/Flexhose
-Crossmember
-Dust Shield
-Bellhousing Bolts
-Assorted bolts and brackets
If I forgot to list something, I have it.
-15 inch alloy wheels with 195/60R15 tires. Will post pics and specs soon.
-Non-ABS Open Differential SOLD
-Complete Brakes (Calipers, Pads, Rotors, Flexlines, E-Brake Cables) SOLD
-Complete Exhaust for KA. Has good cat, resonator and twin tip muffler. GONE
-Parting out complete SOHC KA24E engine, cylinder 3 has low compression, will do leakdown test to determine exact cause.
-PS Lines - Good shape, no leaks
-Complete working AC system GONE
-TPS Sensor
-Alternator SOLD
-Starter SOLD
-Distributor
-Ignition Coil SOLDl
-Valvecover GONE
-Cylinder Head GONE
-Cylinder Block GONE
ENGINE HAS BEEN SCRAPPED, ONLY PARTS LISTED REMAINING
Best way to contact me is call or text six4seven two7four 3sixsix9, PM or reply here. I will post pictures as soon as possible, in the meantime I can send them by phone.
Also have some parts remaining from my 91 partout:
http://www.son240sx.org/showthread.php?281356-Parting-Out-1991-Hatchback
