s14 Blower Motor
Hey guys I was just wondering if anyone has installed or uninstalled a blower motor on an s14. The one that is in there now is apparently toast because it doesn’t blow anything on any setting.
If anyone has done this and can give me some tips that would be great, or if it’s something other then the blower, let me know what it could be.
–Ohh, and are the blower motors in an s13 the same as an s14?
Thanks
Usually, blowers refers to superchargers. If you meant turbocharged motor (which I pray to God you know the difference) then yes, the turbo motor out of a JDM S13 and S14 are different. Same displacement and basics, but minor refinements.
^^^ i think hes talking about the blower for his aircon.
Could be fuses, check those first. Anyways doesnt look to hard to take it out.
http://forums.nicoclub.com/zerothread?id=332633&postid=3594278
Last post should help you out a little, search around theres lots out there
download the fsm and it pretty easily diagnosis the problem…
i just had to replace my resistor which saved me some money… so id check all the small things first like fuses^ etc…
Thanks guys…
Superdave, its not a turbo/supercharger problem…this s14 is bone stock!
Thanks again for the help guys.
S14 blower motors are $90@napa…
I have replaced both mine and my sisters, and tried using the 2 from parts cars… they were all fucked in someway…
when you realize its not the fuses buy a brand new one and don’t waste your time with a used one…
I doubt you could fit an S13 one into the S14 but I never tried
