What do I need to install a 98ka24de into a 92 s13?
Is this a complete swap(motor and harness) or only some parts from one motor to the other one(parts from s13 needs to be installed on the s14motor)?
S14 longblock.
USe S13;
–Intake/exhuast mani’s (disconnect the EGR tube at the intake mani–its much easier) intake mani has the proper temp sensor for the S13 cluster
–MAFS/ECU/harness
–Distributor
–and tranny (for the speed sensor)
other than that your good to go
You could go the entire S14 route, but do you want the updated more complex emissions system? Along with swapping temp sensors and making the two different exhuast systems mesh together…
I suggest; Keep it simple…
