got the problem fixed
u need to say some details all you say is im not sure if somethings wrong or if its just the car?wtf does that mean do you here sounds feel a shake motor has problems starting idle?what you NEED MORE DETAILS
ok… yes there is suppose to be air sound when u let off the gas.
washer fluid is blue
and finally… u can put a battery in the trunk. i just recommend running wires first.
mine’s yellow because i’m jdm.
but sometimes clear when i’m broke.
admin might aswell lock and bury this thread
