I was wondering if my t25 on 97 s13 blacktop can withstand a 14psi boost.
Mods done are
Greddy front mount intercoolers
Greddy BOV
Greddy radiator
and HKS full exhaust system.
I’m getting a AEM electronic boost controller so just wondering…
Mods done are
Greddy BOV
Greddy radiator
you should get bigger injectors. stock injectors are almost out of the efficiency range at 14psi
Stock injectors are WELL out of effciency range at 14psi. 12PSI max on stockers if you want to run 14psi you will need bigger injectors. Mind you all setups and injectors flow slightly different but to be safe unless you have a way to monitor it, 12psi max.
Thanks guys
