Shift_Competition: What's wrong with PJB's 4x4 system?
We all saw it coming: PJB purchases a gasoline Ford pickup, problems (hilarity) ensues shortly thereafter.
We lived with the useless driving and the waste of gas. We lived with the constant washings and waxings as seen in the “What did you do…” thread. We lived with the backing up the dirt hill, barking the tires in 2wd but still being able to make the trip up to the phone pole where Paul then stood on his tailgate and hung a wire up while at work. We even lived with the air conditioning being recharged by Paul JB himself with an ADVANCE AUTO PARTS REFRIGERANT CAN.
However, nobody can live with PJB unable to switch his 2006 F150 into 4 wheel drive. Nobody. At least I can’t. So let’s figure out what’s wrong with this thing.
Post a solution, and the winner will receive a free pint on da house, courtesy of Alpine. If there are repetitions of solutions, we will go with whoever posted the answer first because I’m a college student and have absolutely no money to waste on you jerkoffs, hell I can’t afford to buy even the winner a godforsaken beer as it is.
Now GO! FLOOR IT!
Well this is right up my know it all alley.
Let me take stab at this…
He only purchased the two wheel drive version of the F150 ford was offering in 2006.
Ford just figured it would cost more to pay someone to pull the knobs out of the dash so they left everything there… Except the transfercase and front diff :rofl
hahahahahahah LOL
Seeing as he has a humming sound and no 4wd I’m guessing that he may have a hub problelem seeing as there background actuated and hanging up . I will need to see the vehicle in question to verify my hunch . Untill then back the Fuck off the poor guy or he is gonna get yard brute and wreck some alpine ass.
Paul is very much welcome to participate.
:rofl
pjb you buck
My truck is a legit 4wd and had working 4wd.
I was at work and dont have time to fuck around on the computer all day while there.
And I havent washed the truck in almost 2 months. Damn rain every chance I get.
Combination broken flux capacitor and low headlight fluid. Start pouring.
its definitely because it hasn’t been washed in 2 months. start there.
Free beer, folks.
The problem is circled in blue on the grille
Vacuum pump, vacuum actuator, plugged vacuum lines?
I think the transfer case is shot.
lets start with the fluid level in his tcase and his tranny…is there ANY?
there are 2 fuses to check aswell, then there are the vac lines and solenoids behind the battery on the firewall. there is a start. does the 4x4 light illuminate when you select it? and are there any noises when the initial engagement occurs?
As a point of interest, the 97-03 and some 04 trucks have no hubs. The front axles and CV joints always turn. The axles are disconnected inside the front differential rather than at the wheels. (For 04 and later vehicles, they used vacuum hubs at the wheel end of the axle).
First off, check the 4WD fuse. That has to be working before you can check out anything else.
The two solenoids behind the battery are always connected to battery voltage through the 4WD fuse, so there should always be voltage on them. The 12V is fed to each solenoid through a white wire with the light blue stripe. (W/LB)
There are relays built in to the GEM module (located above the fuse panel above the driver’s left knee). When you move the floor lever, or twist the dash knob, you activate these relays built inside the GEM module. They will ground one of the solenoids and un-ground the other. Grounding the solenoid completes the circuit and causes it to provide vacuum. Un-grounding the solenoid causes it to shut off the vacuum. The ground path for the 4WD solenoid is via the red ® wire… The ground path for the 2WD solenoid is via the grey wire with the black stripe (GY/BK) wire.
To check the operation of the GEM module, you can unplug the connector and connect a 12 volt test light across the 12V terminal and the ground terminal on the plug you just pulled off. The light will come on if the GEM is providing a path to ground. Test each solenoid connector and make sure the appropriate solenoid gets activated as you switch between 2WD and 4WD. If the test light isn’t coming on for one or both of the solenoids, then suspect a faulty GEM module.
If they’re working then you might have a vacuum problem. Make sure the vacuum lines are all OK. Pull out the battery and make sure none of the lines got crushed, cut or cracked by the last person who installed the battery. Also check the vacuum reservoir. It’s a thin black square thing with a vacuum line going to it. It’s fastened to the battery tray on the side closest to the fender. As a note… A bad leak in this area can cause the heater controls to malfunction or not work ‘quite right’… If your heater controls aren’t switching normally, then pay close attention to the vacuum lines.
If the vacuum is OK, then you need to check the actuator. You need to take of a plastic shield to see it. Watch the arm to make sure it’s working… If the actuator is OK, then the lever system that disconnects the axles inside the diff is not working. They do break from time to time. If that’s the case, then the front diff has to be pulled apart.
Look at the diagram of the actuator below and try visualize how the rod will move depending on which side of the diaphragm is receiving vacuum. Vacuum from the 4WD solenoid will push the rod out… Vacuum from the 2WD solenoid will pull the rod in.
just found that on a truck forum…WOW, that was hard
My guess is it was caused by the “tuner” you plugged in
