Short Shifter Removal
Hey guys
I can’t seem to grasp how to remove the shifter, for the simple purpose of putting fluids in.
As you can tell in the following picture there are some allen key bolts but they just hold down half-moon shaped rings. And trust me we tried removing it …
http://img8.imageshack.us/img8/4642/img2599d.jpg
And i can’t see any c-clips …
stop thinking so hard man you`re looking right at the bolts
Literally pulled on it , entire transmission would wiggle
Im heading down with my friend getting his transmission done, i may bring the 240
under the allen key bolts theres the other bolts …as the other guy said dont think to hard
http://is.rely.net/3-99-13811-l-HW8pTCvagxNcCa0iyzaj6g.jpg
There is 6 bolts holding the shifter down.
Google is your friend. Use it. Took me about 30 seconds to find this article:
The back two are a bitch to get at, easier to get from under the car.
u dont have to take out the plate to put fluids in …
http://www.driftconcept.com/2008/08/30/nissan-240sx-short-shifter-install-s1314-180sx-silvia/
do the reverse…
Edit: hell u can even pour it in without taking out the shifter …
Honestly, whats with the smart comments?
The worst part of all, is you were absolutely no help and your lack of experience really shows. You don’t have to remove those 6 bolts.
Reading is your friend
Thanks Dan,
I actually used that guide earlier and found it useful it seems as though the plate naturally cured to the transmission , earlier i attempted to pry it with no luck. Tomorrow i’ll attempt with a mallet and if all else false i’ll just pour through the shifter :smiley:
Much appreciated
Hey did you try taking out the U ring ? Normally short shifter dont have it but maybe you do…
I feel the son240 love in the air… baby baby baby oooh yeaa… lol
That article is great, I used it on my install.
I’ll have to do it again one of these days due to not installing the oem bushing…
wtf
Shit, all you gotta do is unscrew those 4 allen key bolts. then remove the half crescent plates horizontally. Once that is done, the top plate should come out no problem along with the rest of the internals, there could possibly be a snapring in there somewhere.
remove the 4 bolts and the half moons completely… get a pry bar and pry that square peice that holds the shifter in…
