Side panel on case?
I was given a rather nice custom built computer by a friend who is moving to California…
Anyways he couldn’t find the side panel for the case…
Should I just run it with out a side panel or grab a new case for it??
I always stayed away from custom builds so im not sure if temp is going to be an issue.
The only real problem with running it without the side panel is it will accumulate dust faster, but get more airflow. If you can find the model of the case maybe you can visit the manufactures site and request a new one.
Antec 900
I just found a solid replacement on their site for $13…weird they don’t sell the version with the window.
Same one I have. Does they one they give you have case fan holes?
<EDIT>
I also put filters on the front and side of the case to reduce dust. They are your standard filters for heat registers, that you can pick up at Home Depot or Lowes.
http://photos-d.ak.fbcdn.net/hphotos-ak-snc1/hs006.snc1/2829_1133839350297_1356690009_343819_2231951_n.jpg
That looks like complete garbage…
Just saying :shrug: …
functionality > looks :shrug:
^ Exactly. It isn’t supposed to look pretty it keeps the dust out though…You can clearly see how dirty it is. I’ll take an ugly dust filter over clogged/overheating components any day.
I would be concerned that without the side panel the airflow won’t be directed properly. A case is designed to pull air in one end, run it over the components, the expell it at the other end. Without the side panel it’s easy for the same hot air to just keep going in a circle.
Then why the “fancy” case and the LEDs? If you are going to do it, at least make it look better than that!
fuck it the side panel is only $20 shipped with out the window…
My main concern was what JayS about airflow cold air in front hot air out the back.
Word. I put my filter panels under the case panel.
:tup:
It’s not a “fancy” case IMO. The LEDs come standard on the case and really don’t effect my case buying. I bought this because it’s one of the best all around cases, has a huge 200mm fan on top, 2 fans on the front and another in back. I will most likely but the Obsidian 800D in a couple months. With the GTX 285, I need more room and better cable management.
