Well, I have finally decided to learn a little about small engine repair, and have a couple projects started.
I have already done a decent tune up on my push mower, and that having gone well, I have decided to tackle two other projects, but have some questions.
The first is a 30" show blower that I got from my father that was not running. I changed the spark plug, new gas, adjusted the idle screw and was able to get it running again, although it doesn’t seem to have any power. When I push the handle for the auger, it dies out every time. Not quite sure what is causing this, but I am guessing I am going to have to start with rebuilding the carb. The engine is an only Tecumseh HS40-55552J motor. Haven’t found a lot on this specific model, but found some close ones. The Snowblower is a Snapper, and appears to be all original and probably 15-25 years old.
Does anyone have any other suggestions as to what could cause this before I start that? Also, where is a good place (online, or Binghamton, NY) to get replacement gaskets and such for them?
The second project is for my father. It’s an old ariens riding lawn mower. Looks very similar to this one:
[ATTACH=CONFIG]16253[/ATTACH]
This one was running, given to my brother, he used it once and it died on him and would not restart (he has this effect on mechanical items) I went over and looked at it, and the electric starter works, and it seems like it wants to start, but seems to be lacking either gas or spark. When I puller the muffler off, you can feel it pushing and sucking air from there, which I assume is normal cause of the cylinder compression, but would this mean that it isn’t getting air through the carb? Is this again going to be a carb rebuild/replacement, or is there something else I can check.
I am just starting (As of last night) to learn this, as I figure it will be good to know in the future, plus now I don’t have to take them to someone to fix for me. Any help, suggestions, and places to get parts is welcomed. I am pretty sure all my equipment have Tecumseh engines on them right now.
