Almost forgot about this gem… Shortly after the big october storm, this guy “snake”, his buddy “firefly” in a neon roll up to our apartment parking lot. It appears that there is a problem with the battery in Snake’s car. The two discuss it for a while, then firefly leaves for help.
Check out the sweetass snake heads covering the car. There appears to be cables running to them, at leaast to the mirror mounted snakes… Heavy battery drain? Probably!
So snake waits patiently until firefly returns… with what may be the worlds loudest, shittiest RV on close his heels.
The RV idles in the parking lot for nearly 30 minutes… filling my house with pollution: both NOx and Noise. Clearly, snake is not the mastermind behind his car, because there seems to be some trouble understanding how to jumpstart the car… Anyone tech savy enough to outfit their car with illuminated snake heads, could jump start a car in his sleep. Eventually, they manage to finish, and all cars scatter to the winds…
Let’s zoom in a bit here. Check out that sweet headlint tint job. The key to getting the custom “wrinkled look” is to work as much air towards the center of the light. Also, having a blind man apply it in the dark using only his feet helps as well:
i know, right? i didn’t actually spot it. I was in my room, probably sulking over the the loss of the interweb… or painting something “gayly” on my wall. Eviljay yelled for me to come quick… the rest is history.
