I have hear dplenty of times that a skinnier tire is better for snows. Even DTD and tire rack say this…but I want to hear what your .02
Im going to be getting snows for the wifes van and im looking at 2 different sizes. OEM is 235/65 R17 but I can also get 225/65 R17 (no 225/70 R17 available). Im not concerned about the speedo changing 1mph…I am concerned with less rubber on the road. Cutting through snow will be better but what about on those cold dry pavement days. Less rubber on dry pavement = great stopping distance right?
I played this game on the GTO and honestly didn’t see that much of an improvement in the snow going to a narrower tire. Stock was 245/45/17 and I went as low as a 215/50/17 snow for one set. I did notice considerably less grip than the 245/45/17 snows I had when there wasn’t snow. Were the 215’s better than the 245’s in bad snow? Probably a little. Was it enough to give up the extra traction provided by the wider tire the other 95% of the time? Not in my opinion.
Stick with OEM. The number of times per winter where you might see a benefit from a skinnier tire are much less than the benefit you’ll get from the proper size tire.
such a small difference isn’t going to mean much unless you’re threshold trail-braking into every turn and looking for the ultimate edge. when people talk about going thin for winter they usually mean going from like 255 to 225 or something more dramatic. at this size brand to brand differences might even mean they end up the same real width. cause that’s a thing. 225 in one brand is not always 225 in another.
This. Tire sizing can be a strange thing. I changed tire brands for my car and kept the exact same “size”. Once they were on the car I actually had to raise the suspension by a whole inch because the real world tire dimensions were so different.
Last time I checked rubber on the road is measure in area, not width. A wider tire will have a shorter footprint length than a narrow tire at the same inflation pressure. Both “should” have same footprint area. Theoretically a longer footprint will be better at braking, not a wider one. Although I’ve never seen definitive same day testing.
There will be variances between manufactures so this isn’t always true.
