So i was looking through some forums and can across a DIY how to remove the carpet from the door panels, but it never talked about adding anything back on… so it inspired me to do just that!
I went over to the storage unit, and removed my door panels, thanks to the FSM it was easy.
The carpet was next and that was super easy.
For the guys who want to remove their carpet just get a blow dryer and a flat-head screw driver. Heat a corner up, stick the screw driver in the seem (sp) and un-wedge a corner out (seems aren’t really glued down). Next you heat and pull the carpet slowly. Five minutes an it is out.
Next I went out to CT and picked up spray glue and went to fabric land for grey vinyl.
Now the project:
I have never worked with vinyl before in my life, i have used the spray glue before but that is it, all constructive criticism is welcome
Tools used
Taped around the work area
Sprayed glue on the door panel and let is sit for 5 mins to let it get nice and tacky
Next I sprayed glue on the back of the vinyl and let that get tacky, then I laid the vinyl out and heated then pulled and heated and pulled to get it to stretch into form (very hard). I got very carried away in my work that I forgot to take picture of this process, by the time i remembered about the pics i was tucking some of the vinyl into the seems.
Tucking vinyl into the seems, I used the first non-sharp plastic object i could find to tuck in the vinyl (shoehorn)
Once all the vinyl was tucked i cut a piece out of the seems to see how hard it would be, then left it to dry over night
This morning I figured it would be best to cut the vinyl outside the seem so I wouldn’t go too deep and damage the stock vinyl
Lastly I re-heated the vinyl, re-applied a little glue around the seems an pulled and tucked, then i cut the heads off a butch on zip ties and jammed then in the seems to hold the vinyl down. It is now drying and here is how it looks
Thats is my latest project.
Hope you guys like it.
Tell me what you think!
For those who have worked with vinyl, based on the pics, do you have any suggestion for me before I do my other door and glove box? and tricks of the trade?
Thanks
