Hey guys,
Before you go nuts, I did search on the weakass 3 word MAX search tool with many different combinations.
I have been reading all kinds of swap guides and the wiring part never applies because they are all DOHC. And apparently there is a difference between the 2 transmission harnessi(es?).
So the mechanical aspect of the swap is all complete, all that remains is the wiring and a fluid flush.
Has anyone here ever done the 5 speed swap on an SOHC motor? If so please detail the wires and plugs that need to be cut, jumped, and/or altered.
I’ve been checking the schematics specifically for the SOHC but it’s too confusing and I’d like to not make a huge mistake.
Any and all help will be appreciated. If you can come help it would be even better. I live JUUUUST north of the GTA. On the line between Toronto and Thornhill basically.
Here are some pics I just uploaded of the wiring harness where work needs to be done:
Thanks guys,
Dan
