I have a s14 sr20det and I bought NGK BKR5EGP’s Stock # 7090 the discription said 1997 nissan 200sx 1998cc/ 2.0L.
I read up on the correct spark plugs to use but I thought these would be fine for low boost usage. I really dont feel like going back so if anyone can provide some info as to if these spark plugs will work please help.
So the chance of napa or part source having plugs in stock for the SR are probably slim to none right? Is there no other plug that will work that would not have to be special orderd?
BKR7’s are what I run as well and I buy boxes of 10 from Napa for approx $20 taxes in which is just under $2 a plug vs canadian tire charging like $7 for 2.
run the 6s if you are on low boosy >12psi. If you run higher boost then 7s would be good. However they will foul quicker so youll need to change them out sooner. Not a big deal though.
