if u buy a set od lowering springs that will lower my car 1.5 inches will i need new shock or anything?
drop spindles
I would run new shock as a higher spring rate will blow your used/old shocks up very quickly. I would actually just buy coilovers if I were you but that is me.
as said by -the.k.w.c- it would i did it before, at the end coils are just as much
^ x3
dont bother trying to cheap out on suspension… in the end you’ll pay just as much for a crappier setup
