Unfortunately I don’t have a code reader, so that’s not an option right now… I was hoping to get one before I left S-Ontario, but no such luck.
I was under the impression that the #1 Cyl was closest to the firewall/flywheel, since the timing loop comes off the #1 Cyl coil, and that’d be the one closest to the firewall… Can someone confirm this please?
I’m not sure what codes it would be throwing that would cause it to not even start.
A recap of what’s happened with this motor since the last time it ran:
Headgasket wasn’t sealed properly, and OEM studs were used with a metal headgasket.
Unplugged necessary plugs and hoses to remove the head, pulled cams, pulled head.
Replaced headgasket, installed new studs, installed cams ensuring the timing was set (according to the dots) with this guide as reference: http://www.rs-enthalpy.com/info.htm (SR Cam Alignment guide)
Plugged connectors and hoses back in, and it hasn’t run since.
Nothing on the motor was changed except the headgasket and studs.
Motor ran prior to doing that, hasn’t run since.
Today I pulled the valve cover to ensure the cam timing was correct, tried it at TDC, and 180* opposite.
Car is getting spark to all cylinders
Car is getting fuel to all cylinders
Unless it’s throwing a massive code (battery has been unplugged for charging more than once now, so any codes should have cleared, unless the issue was still there), that leaves me to believe it’s a timing issue of some sort, causing it to not run.
That said, without a code reader, I plan on pulling the cams tomorrow and re-installing them as per the guide above, to confirm 100% that they are in correctly.
Now: Can someone confirm: Cyl #1 is closest, or furthest from the firewall?
