SR Wiring Help Urgently Help , Car Almost Burnt Down
So, sorry to make this long but im giving the most detail of the situation i can.
Im doing the battery tray area wiring in my SR and what happens is the following,
When the ignition is turned on, the harness will begin to smoke and the black think wire comming from the SR harness will begin to smoke, only that wire. So imidiatly I turned off the key and disconnected the battery as fast as possible, the insulation on that wire had melted, so i replacd the melted section 10" Long, with new wire, same thing, but this time i held my hand on the wire to see if it was begining to warm up, and shut it off when it did to avoid damage. Origionally I wired up this section wrong, then re did it and the same problem happend!
The motor WILL crank, without a problem and all interior lights work fine and outside lights.
I followed the heavy throttle wiring chart but i found it very confusing
So here is what i have so far, and I have no idea if this is what its supposed to look like,
http://img78.photobucket.com/albums/v252/S13Dorifto/Help/Wiring_Help.jpg
So Basically im stuck.
Would you guys please give me your idea on whats wrong?
Thanks Alot
Im confused why are there 4 wires connected all into one spot?
Where do the Red Wire, Red/Blue Wire and the Brow wire go to?
This is how it should be connected:
SR Harness Wire Color
Use
KA Harness Wire Color
Black / Pink stripe
Fuel Pump Relay
Black / Pink stripe
Green / Orange stripe
Transmission Neutral Sensor
Red / Black stripe
ECU Relay
Red / Black stripe
Green / Yellow stripe
AC Relay
Red
ECU Backup Power
Red
Black / Red & Blue / Red (Note: connect 2 wires to 1)
Main Ignition Power
Black / Red stripe
Black / White stripe
ECU Power
Blue / Green stripe
AC Relay
Blue / Green stripe
Black / Yellow stripe
Idle Air Control Valve Power
Brown (to O2 sensor)
O2 Sensor Power
Any 12v switched source
Sounds like you have a short somewhere dude…
Where I don’t know,
Pull off all the wires, and connect each one individually through
an amp meter and see which one draws the most currant.
Take that one and then check for shorts…
Problem Solved
You are welcome sir.
Turned out to be a grounding issue.
The Brown wire that he replaced with the burnt up black one was actually a direct ground.
scott you’re a silly silly man haha
Now only if Sasha was a silly silly man and we could fix his car that easily.
mines not as easy as soldering grounds and 12v leads together
i WISH i could see the smoke.
Shine glowsticks on the harness and it shall show you the problem.
Now my ground from the motor to the firewall the little clip with braided wire is smoking
when i turn the key the motor turns over once then the connecttion smokes and it stops cranking :cry:
Whats wrong angry
check the ground on your motor from your battery
sounds like your using the little grounding strap to ground your starter motor
Looks like Scott didn’t know that a car’s starter motor cannot ground it self
through that little tiney carroded grounding strap on the back of the block.
It need’s a seperate min 8 gauge wire from the batt to crank through.
It doesnt need 8ga.
Just ground your block, make sure you sand down the paint on your battery tray before reconnecting the main block to chassis ground. You
shouldn’t run the car off that dinky braided ground strap.
It doesnt need 8ga.
shouldn’t run the car off that dinky braided ground strap.[/quote]
It doesn’t need 8ga?
Well it sure won’t crank through that little grounding strap
on the back of the block as Scott found out by trying this.
Grounding your bock is basically what I said by supplying
the Starter Motor it’s own ground wire which needs to be a
min of 8ga to handle the current draw from the starter motor.
problem was, they battery ground from the intake to the battery tray wasnt tightend down all the way so the contact wasnt clean, its all fixed now.
