hey! i have a stock sr20det motor set with just a 3inch exhaust intake and FMIC, i am using the stock SR20det rad, should i upgrade if im just driving my car back and fourth to school/starbucks?
ungrade your rad because your running a FMIC. how badly are you overheating? To the H or what?
do you still have the shroud?
i dont see why you should upgrade no point yet, if your over heating u prolly have like air in ur coolant system or a weak fan or bad thermostat. i have a fmic, 3 inch exhaust and a rad from my 95 its fine no matter what i do. also i had the same setup in my old s13 but with the rad from a 90 240, i over heated for a little while because of wiring for my fan but 1ns that was fixed it never over heated.
im guessing you fixed the last problem with your car what was it the maf sensor.
nono , i didint fix it yet!
im just wondering for future reference.
yeah i still have the stock fan shroud for the KA
so do i need 2 change it? because i really dont have the cash for that :S
and i dont know if it overheats because i cant drive it, the gas lines are leaking,i duno how 2 change it and i dont have 300$ to tow it to a shop, make them fix it, and tow it back
no no need . + its cold out now if u wana upgrade u can do it in the summer if u feel u need it. o yea and for ur other problem i had a similar 1 when i try driving it would bogg like crazy and backfire, my spark plugs were cracked from the top the ceramic part.
ur gas lines are leaking can u see the leak its really easy to fix a leakign gass line especially if u can see the leak, just get a pipe cutter i duno what its called exactly heres a link. cut the bad part off the line and get a hose and two clamps for each end of the hose.
