Ok hope i say this right to understand
as anyone had this problem
I have the spilt fire coil pack kit for sr20det red top and everything is well BUT when i get to the ignitor chip (q45) one of the clips don’t match ((to ECU )) I think the clip was cut off and joined with a different clip for the ignitor …NOW if i have to cut them and join them together (((split fire harness clip and ecu ignitor chip clip))) )I need to know what wires do what…???so i can join them the right way… If i had the clip that went to the ecu to the ignitor chip that had the wires in the clip still then i could just wire the same colored wires together keeping the clip to the split fire clip… its a 5 wire pin clip
Thanks hope i made it clear
