I cant find how to wire the plugs up proplery. anyone know?
Go under FAQ and its there
I’m not sure how to read that or to use it…and all the colours are diffrent exept for the ground
…my ignitor is from a 1995 and looks diffrent.
I’m only getting spark in the first cyl…any ideas why? I’ve tested the coil packs and re wired it to heavy throttle instructions…but the plus looks diffrent…its from a 1995 if it matters. IDEAS???
allright well aperently the 1995 Q45 ignitor and the silvia ignitors are the same part…so I rewired everything back to normal…still having spark from one clynder only.
Could it be the ECU?
Very unlikely
I bet you have the Ignitor wired up wrong
are you sure your coil packs are good? does the code ont eh coilpack match up with the code on the ignitor?
there is 2 different ones! they dont work very good if you mix and match them…i have had cases where they do work and work fine but most of the time if they are mis matched then they dont work!
50-FF-01 it should say that on your ignitor and on the coil packs
50-FF-00 it should say that on your ignitor and on the coil packs
Thanks for sheading some light on this…all the coils work, (I cycled the coil packs through the second cylender.
