Thanks
Thanks
I dont see any kills here lol
You going to be representing the street racing kid in court or something?
thers this place called “youtube” you should check it out
no youtube @ work. Corporate america has grown wise.
Also, it’s not important enough to spend more then two minutes looking for. So if no one knows, then no one knows.
:gotme:
trust me, it’s related. ![]()
side note, my speedo is nowhere near accurate.
roffle
What ratio is 3rd, what’s your final drive ratio, your redline and your tire size? It’s easy to calculate it if you know all of those.
6,250 redline, starts losing power after 5,850
speedo reads 90, but it also waivers 5mph when cruising at 70 in 5th, take it for what is worth.
and as far as shifting goes 5500 is a good time to shift for me which isn’t 6250, or the 6500 cutoff of stage 2 and 3s(chris’s was a stage 2 if it means anything to this)
~ 90 mph. 205/55/17 does 89.0961 mph at 6250 rpm. I run a larger tire so I can go slightly more.
–mark
:tup:
tks.
higher than a mustang,obviously
HAHAHA
Not even close to being true, my mustang did 120 in third with the stock gears.
It was kind of a joke, playing on the tragedy that happened about a month ago
