SSBC Big Brake full kit for GM A, F, X body
Selling a brand new in box, never installed set of SSBC Brakes (Stainless Steel Performance Brakes) that will fit many GM A, F, and X body cars. This was originally intended for a 66-67 Chevelle but we decided to go in a different direction with the build
Will fit many GM applications from 1964-1974 like Chevy Camaro, Chevelle, El Camino, Nova, Pontiac GTO, Lemans, Tempest, Firebird, Oldsmobile 442, and Cutlass, Buick Regal and Skylark.
Front kit is a black SSBC V8 8-piston brake caliper with 12" slotted and drilled rotors and 2" drop spindles - http://ssbrakes.com/i-10092608-disc-brake-kit-front-v8-8-piston-12-rotor-wheel-kit-only-pair-2in-drop.html (Click on the details tab for applications)
Rear kit is a black Tri-Power 3-piston set up with mount for a Ford 9" Torino style rear end. (Other axle mounts are available) - http://ssbrakes.com/i-10092149-disc-brake-kit-rear-3-piston-tri-power-with-13in-rotor-non-staggered-shock.html (Click on the details tab for applications)
System complete MSRP is $3300. Selling for $2300
Great system to upgrade from your dated original OEM brakes and upgrade to modern performance. Perfect for race, pro-touring, or just making your car stop better!
[ATTACH=CONFIG]32588[/ATTACH][ATTACH=CONFIG]32589[/ATTACH]
