steering problem
ok when im driving my 240 on a shallow right turn the sheering cuts right. im just wondering what would case this to happen… my allinment is also off and the steering wheel sits angled right… i was thinking some bushing but im wondering what one… or possably a ball joint? but since im new to this im not sure what could be causing it… or if it is a sevier problem…
Thanks…
Step 1) Inspect the underside of the car for any odvious bent parts. Control arms, shocks etc …
Step 2) Get the car to a frame & alignment place and make sure the frame is straight, then get an alignment.
You’ll find your problem.
thanks.
Jack the front of your car up and check to see if your wheels are loose. Shake/pull on your tires while there off the ground. If they move they’res something loose.
