Okay so when I had my car up in the air the other day doing my clutch I found out the right side boot on my rack and pinion is leaking. Is there a way to fix it or is it better to just replace the whole thing?
Replace the boot.
If the boot is cracked, replace the boot.
If it is leaking it is time for a new rack and pinion.
lowered cars usually go through boots …cv boots / rack boots / dif boots … its good to check them on a regular bassis so you dont have to go through axles or even a rhd rack
