((all updates are on this first post))
This was my stupid plans at first
this is what the body kit looks like installed which it was not it was just siting there.
1 or 2 years later well i started the swap from the 2.0 to the vr6 Turbo
i was building a aba 2.0l with a 1.8 16v head and turbo but it wouldn’t make enough power so i steeped it up
now this is the 2.0l coming out the inside is mostly striped
I picked up my fuel cell , innercooler, turbo kit , prothane kit
10pt roll cage,
what this car is going to be is a 6 cylinder turbo totally gutted with 10pt roll cage , 2 corbau racing seats, 5pt harness , standalone ecu management, nitrous works wet kit , fuel cell , ksport racing coil overs , it will have a aluminum dash and autometer light wait gauges . next i have to hide wiring and grind interior so everything is clean then hole saw every thing that i can. when i need it i will be getting carbon fiber hatch . There are many many more mods that i can list . but don’t have the time i will update as i go.
This week i took out all the wiring left so i could get rid of stuff that i wont be using. Now i will run wiring threw the frame to keep the interior clean. the wiring looks scary but its easy
today i dry-iced the interior to take out all the sound proof stuff
Towmarrow i will shave the rain tray and grind the interior free of burs and spot weld nubs
Then come the cage
small update today i took the doors from 65lbs each to 25lbs
new custom nitrous bracket
new seats and harness
the gauges. left ,Apexi turbo timer, aem wide band air to fuel ,Exhaust Temp, oil pressure ,water temp
coolant reservoir
new smoked directional + air intakes and
new coil overs
better pics of the the body kit that will be on and off the car YES i will be removing the ricer mesh it came with it. and removing z3 fenders
next after cage will be polycarbonite windows (lexan)
welding floor plates with shity welder it is going to my step dads place for the rest of the plates and the cage .
up date : monday i used my work truck to bring the car to my step dads it was fun geting this on the trailer by my self
and on my lunch break i made my seat brackets
this weekend i cut out the spare tire hole and patched it plus patched some holes and welded the plates for the cage
I welded in the plates for the cage out of 3/16 steel plates
welded fire wall holes
long nites in a little garage
my new pipe notcher lol
ps S&w Cages suck imo they are cut to short in almost every way so its going to take a little longer
well tonight we got the 6 points of the cage in 4 more to go
we finished the cage just a couple little things left steering wheel bracket and fix the one strut tower in front
new updates i put in the one more bar so the cage will pass tech scca ECT…
last night i fixed the passenger front strut tower it was rusted throw . so i patched it and today i made a fiberglass plug for the ware the sun roof was . ill take a pic of the fiber glass plug when it dry’s
(fiberglass didnt work errrr)
new parts forge boost controler ,forge deverter valve , spa fuel pressure regulator.
new ecu 034 chiped ,36 pound injectors, 4" maf housing and sensor out of 400+ hp local golf
