I finally got the car all finished, but have been having a strange issue with cooling, almost like a over pressurizing of the system. I fill the radiator up, let the motor run with the cap off to get as much of the air out, and put the cap back on. After a few minutes of running water is pushing past the gaskets on the pump. If you turn the engine off, you can hear an air leak on the passenger head, by the sensor adaptor that will last for a minute or so.
Did, I did some more investigating and believe the issue is coming from that general area. I ran some more fluid through the radiator with the cap of, and it worked just fine. I picked up a new 18lbs rad cap and when the unit started to pull through, I turned the motor off and there is air pulling in from the passenger head that can be heard, but no visual leaks in the area, but coolant will push through the water pump seals. I’m going to get a new barb and see how that works.
Thanks,
Sean
