I have this 2ohm.
what ohm amp do i need to power this
I have this 2ohm.
[quote=“benmtx5,post:21,topic:38170"”]
I have this 2ohm.
[/quote]
If its 2 ohm, hook it up to the amp just like it is, the amp will be fine.
mono or stereo makes no differance to impedence.you could run that amp nt 16ohms if you wanted you just wouldnt get very much power. 2ohm is the lowest you can go. you should be all set with that l5.
