subwoofer help Please and thanks
hey all
I was just wondering if i got
These subs
http://www.cheapcaraudio.us/1000_Watt_Super_Blue_Dual_12_Subwoofer_System_p/carsubj.htm
this
http://www.cheapcaraudio.us/ProductDetails.asp?ProductCode=PBIN2&CartID=1
and this
http://www.cheapcaraudio.us/8_Gauge_Amplifier_Wiring_Kit_p/lq81ps.htm
would this be all i need to wire it up to the stereo battery and amp and subs .
Im really asking is this all i need to put subs in my car and have them work.
Im really stupid when it comes to this but anyhelp would be great thanks
why did u post links to 2 wire kits??? u only 1 kit. are you using your stock radio or do you have a aftermarket radio with rca’s already?
I was wondering which one i need there different gauges. Its a aftermarket stereo it has a ipod hookup so i believe it should rcas
That sub/amp/box combo is crap, If your looking for something cheap your better off buying something used locally.
With that said, Either one of those kits will work. You need power wire, ground wire, remote wire, and RCA cables. 8Ga wire will work, but I would suggest buying a 4ga kit so if you upgrade to a larger amp, you wont have to re-wire your car again.
Iv’e seen 8 gauge melt before, def. do the 4
you gonna need a head unit with rca’s, dont tap into the rear speakers…
I would look for used, I sold 2 JLw3’s in a sealed for $200. few years back
that amp doesn even have an onboard xover your subs would therefore play full range resulting in a good possibilty of blowing factory speakers i forgot the tech term for it but reason being is the two differant size speakers playing the same frequencies cause distortion. i know im close at least.
CLIFFS: dont buy that shit.
buy quality stuff…
if you buy this stuff you might as well throw ur money in the toilet.
Look for used stuff on Craigslist or Buffalo News too
HOLY CRAP that amp is a POS, my friend had one, it put out around 60-80 true watts, and broke 2x… And those subs? Useless… But thats about all that amp can drive. Id look into something better, thats just crap. And both the wireing ‘kits’ you posted were 8 ga wire…
8ga is useless unless your running less than 400w, even then i would run like a 6 or larger.
I ran a 0 ga for my 800w amp, and it loved it… But that might be a hassle to snake through your car. Oh, and if you want power, dont run your ground through your body, run a + and - right off the batt…
Lets recap here, spend $100-200 on a decent amp, $100 on a sub, and i suppose you can buy a premade box that it fits in. Run 4ga to the amp (possibly for the ground also)
And you should be doing ok…
even if u buy sony 12s and a sony 1200w amp its cheap and sounds good
I got 2 Rockford Fosgate 12" in a sealed box for cheap.
