SYNAPSE external wastegate 3 vacuum lines hook ups to where ?????????
40mm SYNAPSE external wastegate Where do i hook up these vacuum lines too there are 2 at the bottom and one at the top …I GOT SOME PICTURES take a look thanks
bump
here you go:
http://www.synapseengineering.com/pdf/wg-manual.pdf
after reading quickly, connect your pressure source to the middle port for simplest operation (wg will open at whatever the spring rate is)
derass you are the men damn THANKS BRO
