[Tech Geeks] Dependency Mapping or Relationship Tool
For the tech geeks out on this forum
I am looking for an application/service that can provide dependency/relationship mapping
Scenarios I am looking to map out:
  • Rack Switch to Host name to host name naming convention (web[01-100].mail.datacenter) to component/HW name (API, Frontend, MySQL DB) to VIP Name (if applicable) to CNAME (if applicable)
  • Component Name (API, Frontend, etc) within a service stack with multiple components to multiple dependencies that the service relies on to function but not owned/supported within the service stack of the component. Looking to map out upstream and downstream dependencies. An example would be IMAPGate hosts have a dependency on service called User Database and Edge Services. User Database to ensure a real email address. Edge services to redirect the user/requests to the closest Data Center.
Any information is greatly appreciated.
Thanks!
Dan
A CMDB probably will do most of what you want. Servicenow is a good cloud offering.
We are currently using ServiceNow but that is now going away because we are moving to Jira, which is more of a DevOps model that integrates with HipChat and Slack.
ServiceNow is viewed as a blocker, time consuming, clunky, and not easily adopted.
However, you are correct because there is a dependency mapping tool.
DevOoops :smiley:
Asset Point I think does this too.
ServiceNow :tup:
It’s cumbersome, but documenting this stuff is SUPER important, even if it’s time consuming. Just another cost of doing business.
You just described every single CMDB system there is… time consuming, clunky and not easily adopted. Basically if it is part of the ITIL spectrum expect it to be shit
It’s refreshing, while at the same time depressing, that I’m not the only one who feels this way.
Thank you all!
Grumble, grumble. Dead on.
I don’t know how something so basic and broad became a standard for something as detailed as IT operations.
Don’t get me started about enterprise applications in general, at least not without a beer in my hand.
