My temperature gauge in My S13 Does not work, i have swapped a S14 Sr in it.
I have been told that the temp senor in the engine has to be changed so that it is the same as the chassis. so i guess i need a sensor thingy from a dohc ka??? straight plug and play??
Secondly i bought a aftermarket electric water temp gauge. instead of getting a DOHC sensor could i not just replace the stock sensor from the Sr with this new one from my gauge, or will my ecu not like that?
i don’t know if you misunderstood or if i did. if i were to replace the sensor with my aftermarket one and use the aftermarket gauge. will my ecu not like having a signal at all since ill be using an independent unit.
