pics or ban
ive seen a fully built d series with p30 pistons, custom rods, head work, a bisimoto header put down a lil over 160whp and run 11’s…oh yea it was in a 4 door
how do 81mm p30 pistons fit in a 75mm bore D series?
i didnt want to say anything but…lol
some people think nyspeeders are dumb…lol
he had them in there…i have him on myspace or something i dont remember but he barely had any cylinder wall i didnt think it would last but it did and ran pretty strong
Most of them are
81mm pistons in a 75mm bored (max with sleaves is 79mm) is not possible unless they had the pistons custom made in that size, even then for the amount of money spent there are much better pistons that bolt right in such as d16a1 pistons
Dont be stupid they probably just machined down the pistons to fit… :rimshot:
great thread here :lol:
It has been done in the past. I doubt any of you are old enough to have been on the old Endyn forums. It didn’t make 300whp, but it has been done.
Bisi use to hang out on the sohc forums before the monstrosity that is the dseries forums came about.
He ran a D series for a long time, and if memory serves, it was destroked to 1.4l, and had a pretty slick carb setup. Last I spoke with him, it was a F series with an adapter plate so he can continue using the D series trans.
Anywho, if you aren’t posting dyno charts, then do not hit the “Submit Reply” button.
You have all been warned.
Bisi’s current set up:
F22A1
17:1 COMPRESSION RATIO
420+ WHP
BISIMOTO H2D/F2D KIT
BISIMOTO VALVE SPRINGS
BISIMOTO CAM GEAR
BISIMOTO LEVEL X CAMSHAFT
BISIMOTO HEADER
BISIMOTO HEAT SHIELD GASKET
BISIMOTO SPEC. ARIAS PISTONS
SUPERTECH VALVES
KINSLER 60mm ITB
KINSLER MECHANICAL FUEL PUMP
ALUMINUM PISTON ROD
AEM EMS WITH COIL PLUGS
AEM TWIN FIRE
SPINWERKES WHEEL
TOY0 SLICK TIRES
i have seen p29’s in a D15he is on my myspace he is in Seattle Wa. there was like no cylinder wall at all on the black
note not much cylinder wall
the p29 pistons are pistons from the d16a1 i was talking about, and they are made for the d series bore, thats plenty of cylinder wall, if you had an 81mm piston they would be about touching each other
yea i kno what you were talking about saxon…i think hodge was thinking of that since i showed him that picture 1 night
IN for results.
