timing gear drive ???s HELP!!
why can i use this (or any) gear drive for hydraulic lifter SBC???
http://store.summitracing.com/partdetail.asp?part=SUM-G6700&view=32&N=700+115
It says not to be used with hydraulic roller camshaft vehicles because they have different timing gears. Also it isn’t a good idea to use this on a fuel injected SBC because it can and most like will set of the factory knock sensor and pull timing like crazy. It will sound cool and perform like shit
got to buy the lt4 knock sensor if you’re going to use them noisy drives
[quote=“BrockwayMT,post:3,topic:27607"”]
[/quote]
That won’t even do it…
Depending on what motor you are putting it on; if it’s an LT1/LT4 motor, then you have to modify the timing cover for it to fit; program out the knock sensor completely, and run an electric waterpump. Plus there’s one for hydraulic cam motors I believe.
i ran one for a few days and hated it. at first i thought it was awesome and sounded cool blah blah blah, but then all you can hear is that stupid thing whine. got really annoying. and keep in mind, it takes power to run one of those too…
